It is currently Sat Jul 19, 2025 2:10 am
PostPosted: Thu Sep 14, 2006 4:27 pm
If no adjustment is needed after the neck is setup, I go ahead and turn the bolt just enough to tighten it so it won't rattle but not enough to adjust the neck in either direction.
PostPosted: Thu Sep 14, 2006 5:01 pm
I always put a little dab of "tub & tile" calk in the slot, usually near both ends and the middle. Just a small dab in the bottom of the slot then press the rod down. I've never had a problem with rattles and it dooesn't interfere with adjustments either.
PostPosted: Thu Sep 14, 2006 10:07 pm
Good tips guys, Thanks!
PostPosted: Thu Sep 14, 2006 10:31 pm
Hi there Serge, Good morning. It seems you and I are the only ones up at this hour.
PostPosted: Thu Sep 14, 2006 10:40 pm
PostPosted: Thu Sep 14, 2006 11:32 pm
I had the same problem with a bass guitar, but just snugging the trussrod took care of it. I use Shoo Goo now.
Just a tiny bit does the trick.
PostPosted: Fri Sep 15, 2006 12:33 am
Hi John, sorry for being late to reply, i guess we woke up a bunch eh?
PostPosted: Sat Sep 16, 2006 12:27 pm
What does "bump" mean?? I see some post this term from time to time
PostPosted: Sat Sep 16, 2006 12:35 pm
Rich, "bump" just moves the thread to the top of the stack or list by creating a recent thread entry. It "bumps" the discussion back up to call attention or remind folks that more commentary or discussion is desired.
